b/c to A cut
b/c to A cut
    MPR FAB southwind011's Avatar
    riverside ca
    Default b/c to A cut
    i am going to rebuild my pump and it has a b/c cut and the kit has a A cut. what will i gain and lose and can i put the th b/c back in and put the a in when the motor is rebuilt. i will be rebuilding the motor but not right away
    Nov 2009
    Yes you can put the old one back in. With the "A" you will lose probably 500 rpm but it will be better out of the hole with it. If your motor needs that 500 rpm to get where it makes the best power have the new one cut.
    ...gps it before and after and then you'll know what way to go
    show your tits topless000's Avatar
    It will leave real hard and you will like it!!!!!!
