found my project
Results 1 to 14 of 22
found my project
    Jul 2009
    Default found my project
    Think I might have found my project jet (sorry for the crappy cell pictures) part of divorce deal so the lady doesn't seem know much about it but its 18 sleekcraft and has a 12j Berkley jet which looks good , no motor guess it had an oldmobile and the jet shaft turns over but kind of sounds "gritty" ? probably needs some work inside
    What do you guys think for $500 bucks anyhow
    Gene
    Senior Member CK7684's Avatar
    Minnesota
    Hard to tell from the pics, but if the hull is solid then it looks like a fun project!!
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    Hell its a Sleek with a split bowl what more do you want.
    Glendale Arizona
    As long as the pump isn't completely hosed............that alone is probably worth $500.
    Quote Originally Posted by genensandee View Post
    Gene
    Gene ,the grit or grating could be a little sand or grit between the wear ring and impeller however if the boat has been setting a for a while (and it kind of looks like it has) I would give thought to "freshening" the Jet as part of your project for sure and like said the jet is probably worth the purchase alone Tom
    Member sleek73's Avatar
    Gardnerville, Nv.
    Great boat to have as a project. The below link is a post of my rebuild. You'll have a blast. Keep us posted as you go.
    http://www.performanceboats.com//sho...hlight=sleek73
    Jul 2009
    Quote Originally Posted by sleek73 View Post
    Thanks for the link sleek, I'll check it out, and thanks for all the encouragement guys , going to go for it and decided we will try to take the jet apart this weekend , FIL is a auto mechanic ,says he can help Gene
    Jul 2009
    ok were on a roll but need help , got the Jet out and the big rear housing seal off but cant get the big nut off the back of the shaft behind the prop , how do you hold the shaft or do you push everything out of the main body through the big bearing , oh ya it says 12jga
    Gene
    Gene, you will need a 1 13/16 Jet drive deep socket $$ or same size wrench preferably. Or you may be able to use a large Crescent for the task , with the jet out of the boat holding the pump shaft may be a little tricky , if you have the drive line (or the splined input part) you might be able to make use of it to hold the splined end of the shaft while removing the nut This may be a 2 person job with out power tools , feel free to call or Pm if you need help Tom
    Senior Member bp298's Avatar
    LHC
    Gene
    http://www.cpperformance.com/SearchR...CategoryID=530
    http://www.rexmar.com/page126.html
    Colfax, Ca
    Where are you located??
    Jul 2009
    im in san diego , got the nut off, now working on the impellar
    Jul 2009
    got flippin impellar off , thinkin this jet is bigger than me , looks simple but we will see, anybody know what these grooves are on the impellar? Gene
    Senior Member MR.Magoo's Avatar
    keep the pics coming gene, looks like a great project boat. good luck with the boat
