Impeller Cut ?
Results 1 to 8 of 8
Impeller Cut ?
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Default Impeller Cut ?
    I'm looking at trading my A- aluminum for this SS impeller. Can someone tell me what cut it is. Looks to be in good shape.
    Thanks Ron
ID:	64588   Click image for larger version.
Name:	g berk. 004.jpg
ID:	64589   Click image for larger version.
Name:	g berk. 002.jpg
    Looks like it needs a tune up. Trade as in even up... or trade with some additional $$. Leading edges are a bit hammered for SS, Wear ring area is more critical, than a few dings.
    cut looks to be a "B" or an "AB"
    x2
    Valley Center Ca
    Thanks for the input.
    I'll have it check out
    B1 Racing cs19's Avatar
    def. not an A. Been cut significantly.
    could be the camera but i am seeing some kind of strange angle that it has been cut, also be sure to mike the wear ring skirt and be sure it has not been cut or you will have to have a wear ring also for the proper clearance.
    Quote Originally Posted by johnray069 View Post
    Good Call.... John Ray
    California
    It was smaller than an A before the blades were cut down. Compare the large OD against the register in the first pic(the register is 9.125). From the pic i would guess it started out as an A/B or a B. See how the small diameter and the large diameter have a little of the blade angle cut into them, berkeley used to cut their b's that way instead of just cutting the blade up to the hub on the small end and reducing the large diameter, it wouldnt look like that if it started as an A. I'd guess it was a B/C or a C now with the additional blade cut.
