nozzle inserts
Results 1 to 10 of 10
nozzle inserts
    Default nozzle inserts
    has anybody machined a place diverter to accept the slip in inserts?
    Senior Member bp298's Avatar
    LHC
    had mpd machine mine many years ago.
    Swollen Member
    Austin, TX
    Mine came machined from Place. The inserts are different than those from Aggressor.
    Phx
    Default two different styles
    If you have the old style, there is not engough beef to machine out. If you have the newer style with the flat bottom then all you have to do is get someone to open it up to the appropriate size.
    thanks for the replies I have a newer one,
    MI
    Just send it back to Place they'll do it for ya.
    So what size does everybody end up running?
    mine is 3-1/8"
    MI
    At the moment mine is 3-1/16.
    Quote Originally Posted by sanger rat View Post
    Mine was machined aleady. I experiment with 3 1/8-3 1/16 amd 3 3/32. Each one gives a distinctive ride. 3 1/16 gives me better pf. Should have it machined or tap it to change it out as needed.
    Place has nozel reducers by color code ready to install with one screw.
    If your nozel is 3.25", Anyone with a mill can cut it for ya...almost never does a 3.25" nozel get the pf on a lake boat.
    LHC
    mine is 3-1/8"
    currently, i'm using 3.03, 3.02, and 3.00. for my deal, 3.075 or 3.08 seems to be the best combination for et (acceleration) and speed, but i'll be doing some more testing. i made a 3.05 that was a bit different than a standard ftn, tried it last weekend, and the holeshot was much harder.
    just keep them coated with antisieze, remove them after every trip and clean them up. i've seen these things weld themselves to the nozzle, and they can be very difficult to remove. with the ftn's from rex at $50.00 a pop, you want to keep them in good shape.
