Trying to take out motor........
Results 1 to 11 of 11
    Member TrynPas's Avatar
    Litchfield Park, AZ
    Default Trying to take out motor........
    I'm in the process of trying to pull my 460 out and can't seem to get it to slide forward. My old boat had a 460 w/Jacuzzi jet and I'd just lift the motor about the mounts and slide it forward off of the shaft at the pump. This one's a Berkley and I've taken off the bottom half of the connection (clamp) at the pump, but it won't slide forward off of the shaft. Am I missing something? Do the two angled bolts (on either side of the name plate) have anything to do with it? The Jacuzzi was pretty much exposed and made it easy. Thanks in advance for the help.
ID:	64690   Click image for larger version.
    You done got my kentucky ass all confused!!!
    Morgan Hill
    I would lift the rear of the engine a tad more to clear the bearing head flange raising the front of the engine even more, there is a pretty good chance the splines are stuck, try using a dead blow hammer or mallet and rapping the yoke a few times while trying to pull it forward.
    I have also moved the engine from side to side to get them to free up, good luck...
    edit;Also, if the yoke was greased recently, it could be vacuum locked, try shooting some grease in the yoke if it has that option to push it off the shaft...
    GT
    Santa Clarita
    Just man handle that bitch and push her forward....she'll come loose.
    Try taking the mount plates loose from the engine (to clear) , reduce the lift and pull the motor out straight forward Tom
    Default U joint angle
    It is easier if the u joint can flex in the desired direction, like up.....If the u joint is angled @45* it can bind up on the spline. 90* is desirable.....Ray
    LOUD BOATS SAVE LIVES
    Litchfield Park, AZ
    GOT IT. I guess it was just plain stuck. Used a dead blow, wiggled it, and finally just pryed it forward through the little oval hole over top of the u-joints. Now that I think about it, I may have done that same thing a few years back the first time with that other pump. I'll clean the hell out of it before I put it together, hopefulley that will make it easier in the future. Thanks for the help, didn't want to break something.
    Senior Member milkmoney's Avatar
    vegas
    god dam bobby when did u get a boat, no pics or even a thread of look at my new sled.. how ya been?
    Nov 2009
    Langley, B.C. Canada
    the angled bolts in the pic are to put more press on the rope packing
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    I agree! Put your back into it PUSH
    Litchfield Park, AZ
    Quote Originally Posted by milkmoney View Post
    Hey MM, how's it going? Signed on a few days back and didn't see any sign of you. Looks like HJ is gone too? Is it possible that he ran out of questions? Regarding the boat, I sort of got trapped into it. My buddy (from Henderson, NV) parked it at my house about a year ago (without a cover), so after trying to keep it out of the sun and other elements all this time (mostly unsuccessfully), he told me he's in a real financial bind and wants to sell it. So I figure instead of cleaning it up for him and helping him sell it, I'd just give him the money he needs and keep it for myself. If I'm gonna do the work, might as well reap the rewards, right? Anyways, it leaks oil and just looks like hell so I pulled the motor to 'freshen' it up a little. Hopefully I'll get it done and meet you at the river soon.
    Litchfield Park, AZ
    Quote Originally Posted by lefty's pride View Post
    Cool....thanks. That's another part that I don't remember on my Jacuzzi. I know that Berks are considered better, but that Jacuzzi was so damn easy.
