droop
droop
    Senior Member slotracer's Avatar
    Default droop
    will a droop from a dominator bowl work on a jg bowl?
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Senior Member Tony Skagen's Avatar
    Yes!!
    California
    Quote Originally Posted by Tony Skagen View Post
    Yes!!
    x2, if its used try and determing the vintage by fitting your nozzle into it before your buy it, if you can. Early Dominator Stuff had a slightly Larger OD (like .125) on the sealing surface of the nozzle. If it was produce in the last decade and 1/2, or so, you should be fine. The fix for using an early Dominator Droop/nozzle extention with a Berkeley style nozzle is to space the o-ring out, it will work ok.
    BTW a Droop to fit a Berkeley produced by AT is called a Dominator Droop
    thats good to know. more parts are on the way for the next project.
    slot
    87 eliminator
    Stockton, ca.
