How are you recording speed with your data logger?
Results 1 to 6 of 6
    Back into Boats Beal Motorsports's Avatar
    Dec 2009
    Kansas City
    Default How are you recording speed with your data logger?
    I'm looking into data loggers. My boat has a Norskog but we want to record it. Would you just use a pressure transducer and equate pressure to speed?
    Also how are you mounting them?
    Thanks.
    San Diego, CA
    Quote Originally Posted by Beal Motorsports View Post
    Thanks.
    The short answer yes. The old qwik data will record the data for you from a pressure transducer and give you a graph showing readings, I believe it takes data 500 times per second. This display with be shown in psi which can be easily converted into mph and is quite accurate. The equation for psi to mph is
    PSI(square root) x 8.31 = MPH
    Example
    144 PSI (square root) x 8.31 = 99.72 MPH
    The new qwik data II can do the conversion for you and the graph will show mph. Racepak is also this way that it will do the math for you.
    A few of us are running a speedo pickup tube located on the skeg of the intake fins.
    I have another boat that this was not possible to do since the intake was already in the boat. So I made a pickup tube hang off the back the boat.
    Both of these have a small nylon tube running up to the transducer that is hooked up to the data logger.
    Boat 405.
    Example
    any pics of the pickup tube on the intake fins? this would beat drilling holes in the transom
    #55
    B1 Racing cs19's Avatar
    Its no easy task, better off running one off the transom.
    Shell Knob, MO
    Beal Motorsports.
    Sent you a PM.
    Duane HTP
    Dec 2009
    Kansas City
    Thanks guys.
