BBO - Why the notch in bearing?
Results 1 to 7 of 7
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Red face BBO - Why the notch in bearing?
    Why is there notches in the STD GM big end bearing and no notch in the Clevite 77?
Name:	BBO - big end - Clevite 77.jpg
ID:	64847   Click image for larger version.
Name:	BBO - big end bearing.jpg
    Quote Originally Posted by Jet mad View Post
    Notches are the method of installing the balls. Every Bearing mfg. has his own described installation instructions towards setting the bearing. Some want notch forward, others want it towards rear. This has to do with the frontal load designed in the bearing.
    Monroe, WA
    Those aren't jet bearings in those pics, Pops.
    Some original rods had groves out the mating surfaces to oil the cam.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    seattle
    Default clevite 77
    i used clevite 77. they have held out for 7 years of punishment!!
    Quote Originally Posted by Malcolm View Post
    Pops & Malcolm,
    The rod with the bearing notch is a 1975 BBO - Marine spec engine rod - stock std -
    Oiling the cam ? If I am not mistaken the oil feed for the cam comes from the mains on a BBO -
    I belive you will find the small round notches relate to rod big end oil "squirters" Tom
    http://books.google.com/books?id=TXE...age&q=&f=false
    Tom,
    Thanks for the link, makes for intresting reading and it answered my question.
    Jet Mad
