sbc front motor mts
Results 1 to 7 of 7
sbc front motor mts
    Default sbc front motor mts
    does any body have the measurements for the front of the sbc? will you post them up please.
    Member blownt's Avatar
    Houston, Texas
    need the bolt holes dimensioned please.
    Southwest corner AR
    Are you looking for up and down or one side to the other or both? WT
    WT
    WFL Crew!!!
    both the front four motor mt holes in relation to the crank centerline
    Senior Member Xerophobic's Avatar
    Calgary, Alberta, Canada
    I have these dimensions too (altho Im not proud of it! )
    Please verify accuracy before you use them. Again its not my drawing so measure a block first. I cant post a drawing now but here are the dims
    Holes are mirrored from the centerline
    Lower hole is 0.375" above the crank centerline and the upper hole 2.000" above the crank centerline. Both holes are 4.500" laterally off the motor centerline
    Upper holes are both 4.200" off the motor center and are 6.140" above the crank centerline and 7.940" respectively.
    The water inlet holes are aprox 7" above the crank centerline and also 4.200" off the motor centerline
    Hope this helps and if anyone can verify these, I too like to double check their accuracy
    Cheers
    If you ain't hittin bottom...you ain't jetboatin!
    Houston, Texas
