Need help identifying Jacuzzi jet
Results 1 to 5 of 5
    echo bay / las vegas
    Default Need help identifying Jacuzzi jet
    I've got a diverter type thing on a jacuzzi jet, does anyone know how to rebuild these or where to get the parts to rebuild these? Or anything about them?
    James that is an original Jacuzzi YJ and Golden Eagle hydraulic nozzle trim , The unit itself is long since obsolete but when it works is works as designed , Some limited parts are still available (like a seal kit for the hydraulic ram) It uses a fairly standard Out drive trim pump (OMC as I recall) Tom
    Do you know where to get a seal kit?
    Senior Member Beerguy's Avatar
    Lake Havasu AZ.
    If I were you, I would have Tom do it!! Just my .02!!
    Save the Salt
    Quote Originally Posted by echobayjames View Post
    Yes Jacuzzi (Namj) still sells the oring and wiper seal kit for the actuator ram Tom
