Impeller help
Results 1 to 14 of 18
Impeller help
    Default Impeller help
    Whats the best Impeller nut to use? I have a aluminum one and a steel one with a nylon insert/ nylock.
    Also is it normal for a new impeller to have a big ground down notch in the very outside diameter? is this for balancing?
    this is a new American turbine stainless one
    #55
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    I was curious about the same thing!...where mine was ground on was for balancing i was told.
    Q.C./Big River
    Quote Originally Posted by toddnjuzz View Post
    x2
    Shell Knob, MO
    Yes, the grinding on the side of the skirt is the most common way for a factory balance job to be done. Both nuts work just fine. The Aluminum nut is less likely to pull off the treads after being installed for a long time.
    Nov 2009
    Langley, B.C. Canada
    do you mean the machined surface at the wear ring? (like the rings on the pic or something else) i was told that the rings where machined into the impeller to help with sealing.
    here is a pic of where it was balanced, apparently this is normal with a stainless impeller
    #55
    Nov 2009
    OK obviously not what i was talking about, i with draw my statement. never had a SS imp. looks like balancing.
    oldsmopile equipped
    Lake Lansing MI.
    that's where my aluminum impeller was balanced by amt, so its not just a ss thing.
    Thats normal production balancing, they are pretty spot on balanced too.
    If using the aluminum nut, or non locking type nut, be sure to put on some locktite or it will come loose.
    X 2 on the aluminum over the steel nut, saves the shaft.
    B1 Racing cs19's Avatar
    Outlaw, dont panic.. Its only balacing.. Its a good thing!
    San Diego, CA
    I thought this is what happens when you run the pump out of water.....
    Boat 405.
    Nov 2009
    nope, that is the way it came. in the early life of the boat it broke one of the grate rods and it destroyed the first impeller, it made it part way through the impeller and did i good number on the bowl. so my father ordered another impeller and it came with three groves machined in the surface, he called to find out why the old one had none and the new one had them they told him it was to improve the sealing, note the impeller that replaced that one did not have the groves. has any body else run in to this and have a story ?
    Quote Originally Posted by lefty's pride View Post
    My pop; Jac Sea did that to all his impellers,and all wjr Jacuzzis came with it. I have seen several other people do it over the last 30 years of rebuilding pumps. It is supposed to help seal the wear ring. Dont really know if it works but it certainly doesnt hurt anything.
    Shell Knob, MO
    Those are known as a Libreth seal. They are supposed to break up the flow of water between two rotating surfaces. They may help some, but I've never found it to be a measurable amount. Duane HTP
