Winter upgrades
Results 1 to 14 of 24
Winter upgrades
    Default Winter upgrades
    Alright you guys, what offseason upgrades are you doing to your boat? Mine is new supercharger, boost guage, make my tach work and maybe MSD system including new msd plug wires. Pat
    Senior Member GRoper's Avatar
    putting a previouse motor (468 bbc) that I had blown up about 4 summers ago back together, trying to find a tunnel ram for it (they look cool) and put it back in the rogers and see if I have better luck with it the second time around.... (this time ill check the piston to valve clearence )
    Senior Member Futs's Avatar
    Orange CA, Big River
    vroom vroom
Name:	river avi 007.jpg
    Default Nice picture!!!
    Thanks Tim, thats a nice pic!!!
    031 RIVER4FUN's Avatar
    Rings, bearings, B&B pan, & a new cam from Cstraub.
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Some will say I'm going backwards. Putting a FORD mill and got rid of the bowtie. It'll pay off when it's done!....I hope.
    Tim-Glad to hear the motor is okay from the TP deal. See you out in the water @ Memorial.
    Tacoma Wa
    New rods, bearings, pistons. Heads re worked, all aluminum re polished, new false bottom, rail kit, intake re set, intake cut for a shoe, ride plate, bottom work, and quite possibly pump work.... its been a few winters worth of upgrades but getting closer... if I'm lucky maybe she'll float and move under her own power this summer.
    Default new aluminum heads!
    new aluminum heads!
    Shell Knob, MO
    Porting and Polishing heads, Total seal rings, Brodix Intake Manifold, Stage III HTP Solid Roller Cam and Kit, Hi-Helix Impeller and some Dyno time on the motor. (For my Grandson's little boat). Duane HTP
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    bought my race boat a 28' enclosed trailer
    Redding, CA
    Tom and Josh reset intake, cut for and installed shoe and plate.
    They also went through the pump and checked it out. (It was a new JG swap with diverter and droop)
    Also converted to braided diverter lines.
    Last year was entire new short block all forged and internally balanced BBC, with new Hyd. roller. Freshened up the Brodix heads then also.
    But the pump and intake troubles I had (Many of you probably saw Tom's thread on it) wrecked the entire summer, 4 hours of boat time, 3 of them bad!
    So this summer will be like a whole new boat.
    FINALLY installing my trim indicator gauge.
    Also have all the parts now for complete new fuel system for the Hydro, so after Miller is done, I'll tackle the labor end of the Red boat.
    PS- Hey Tom @ JBP, Deb said the transom seal nut dealio showed up last Saturday, Thanks again!
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Member RTRIEBESS's Avatar
    Roseville, CA
    intake rest, new pump, minor bottom work, gauges, wiring, painting stringers, carpet, new steering and super chiller if everything gos as planed
    im doing an oil change, might put new plugs in it..
    Q.C./Big River
    Just a really good wax job to get rid of some oxidation!
