455 olds ????
Results 1 to 14 of 73
455 olds ????
    Nov 2009
    Question 455 olds ????
    Ive got a 455 with block FA and F5 I want a relieable 450hp motor tell me how to do it cheap heads are J double springs
Name:	rainy day at the lake 001.JPG
ID:	66047   Click image for larger version.
Name:	rainy day at the lake 002.JPG
ID:	66048   Click image for larger version.
Name:	rainy day at the lake 003.JPG
ID:	66049   Click image for larger version.
Name:	rainy day at the lake 005.JPG
    Not that an Olds won't do it, it's the longevitiy that suffers upping the HP in the OLDS, they will last for ever in stock form. Seriously a Ford or Chevy would be much more reliable @ 450hp...
    Alamogordo NM
    Default olds
    check out realoldspower.com, but I think sleek is right. Just as a reference larger bore= hp longer stroke=torque (oversimplified), and the olds 455 is really just a small block with a taller deck and longer stroke.
    Monroe, WA
    I think you could do 400 with that setup but not 450. The J heads are not known for their great flow. You say cheap, how cheap you talkin'?
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Best cheap way is to buy a 460 Ford or a 454 Chevy. Sorry.
    Lake Havasu az.
    x2
    Sheriff Joe Arpaio
    Nov 2009
    I will possibly get a set of wa heads soon that will help
    Aug 2009
    I'll second the trip to realoldspower.com...all the info you need is there.
    I'm in the same boat(terrible pun I know....)....currently have a 455 that is toast, and instead of swapping out to a ford or chevy(even thought about pulling the v10 outta my dodge....."pipe" dream I know...lol). But for simplicity, I am just going back to the 455. I picked up a couple "running" junkyard motors, one to drop in and get wet, the other to build with all the tricks needed to keep the 455 together for extended WOT fun.
    In my *very* limited experience I would worry more about torque than hp....and keep the rpms under 5000 if you want "reliable".
    What are "wa" heads?
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    There is no way to get that HP range cheap. I have done a lot of reshearch regarding the 455 Olds and to build a reliable one takes a good engine builder that knows the machine and all the tricks.
    1. Restricted Pushrods.
    2. Resrtict oil galley on mains to cam.
    3. Restricted cam bearings.
    4. Nodular crank.
    5. Enlarge backflow oil galleys in heads.
    6. Debur lifter valley.
    7. Modify conrods.
    8. H/V oil pump.
    and the list goes on.
    Oh, and you can listen to Malcolm - I using the advice he gave me on rebuilding my engine.
    Most important is the tolerances on the big end and main bearings.
    Been there done that
    PS. And I am a big Olds fan. Don't do it cheap do it right the first time.
    Quote Originally Posted by camusmuse View Post
    "Wa" heads are a Irragation/Marine prepared heads - You get Ka an Ga heads as well. hardended seats, big valves etc.
    If the engine number is as follows 5L 345253 it means the engine was designated for Marine or Irragation pump use.
    with your ol lady
    The most important thing is to NOT listen to the chubby and ferd guys.
    No more Mr. Nice Guy !
    Monroe, WA
    Hmm, never heard of Wa heads.... I'm running the Ka's tho...
    Malcolm
    75 Spectra 18
    Quote Originally Posted by Malcolm View Post
    Yip, I had a look at the Olds site, no Wa heads
    Honda1
    Can you give me the Casting nr on your heads?
    Will give you the specs on them.
