Berk. 12-jc thrust bearing failure
Results 1 to 9 of 9
    Default Berk. 12-jc thrust bearing failure
    Hello All, I've got a 73 Glastron Carlson CV-19ss with a pretty healthy 470 Olds turning a Berkeley 12-JC A. The thrust bearing in the Berk is starting to make a fair amount of noise. Any of you long time jetters knows how quick they'll go from noisy to catastrophic failure?
    Any chance anyone knows a good Berkeley rebuild shop in Colorado? I'd pull the engine and yank the pump this winter, but I'm hoping to make it through another season before taking the boat down again.
    Thanks!
    Tim
    if its making noise, it could fail anytime. get it repaired before it takes out the engine too.
    #55
    Shell Knob, MO
    You're playing with disaster running it any more at all. Fix it while it's still cheap to fix. Once it goes out it gets real expensive. Duane HTP
    Nov 2009
    Langley, B.C. Canada
    i was told a worn thrust bearing could take out a motor, soo... change it out
    x2 with duane, worst case is if it doesnt sink your boat you may be looking at pump replacement=have seen several that tried to make it back to the dock that had no rebuildable parts left. fix it now it will be a lot cheaper.
    Nov 2009
    Quote Originally Posted by cv19 View Post
    Thanks!
    Tim
    call Tom at Jet boat performance in cali will ship complete kit and walk you through it not a hard task 805-975-5155
    Thanks for all the advice. Looks like I'll be pulling the Olds for the 4th time
    California
    You shouldn't have to pull the engine out to remove the jc.
    Member Rogers daycruiser fan's Avatar
    Orange County,CA
    I di not need to pull my engine to pull my pump, I little work but way easy.
