Through transom headers?
Results 1 to 13 of 13
    Ralphs club member LSXINDUSTRIES's Avatar
    Dec 2009
    Van Nuys, CA
    Default Through transom headers?
    Is it possible to take headers, weld water injection bungs on them, and run them under a engine cover in a through transom environment? Similar to CMI headers, factory Mercury racing headers used on 600sci motors, 525's , etc? Im still planning on putting a LSX into my day cruiser, but not looking forward to spending $1200 plus on a set of jacketed exhaust manifolds. Thanks for the info!
    “I am on a drug. It’s called Charlie Sheen. It’s not available because if you try it, you will die. Your face will melt off, and your children will weep over your exploded body.”
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by LSXINDUSTRIES View Post
    Injected headers get way too hot to cover them up. If there is any hint of gas fumes under the cover, it could cause a pretty good sized kaboom.
    The jacketed headers are cooled with water so they don't get any where near the temps the injected ones get.
    Dec 2009
    Van Nuys, CA
    yea, i pretty much knew it already. My wallet was hoping somebody would prove me wrong!
    Cas
    Cas is offline
    10 or 12 coats of ceramic might get them cool enough
    LXI you might be surprized at the prices of some OEM "take offs" out there ,we found these recently for a really good price and used them on a SBC for BBC swap Tom
    Dec 2009
    Van Nuys, CA
    Id love to find a takeoff set of LS series marine manifolds. Im sure they are fairly scarce though as of now, but if anybody sees any, let me know!
    I think it was talked about before but, why not build an adapter, use a set of ls flanges to adapt the exhaust of the most similar design.
    you can build your own log style headers coat and wrap em you're not gonna find any used ls marine stuff, i know i had to build my ls turbo headers the way i wanted just to make it look and work right, i built long tube primary log style headers for it. i'll put some pics up after they're final tigged, was sick last wk and didn't get much done they look really good though
    Bakersfield
    LSX-
    I have a nice set of polished Drake center risers with s/s downturns for sale.
    Discount Inboard Marine has them new for the ZR 6.0 supposed to be the same as the LS1-LS6, should be correct fit for any Gen III V-8
    http://skidim.com/prodinfo.asp?number=R029016
    http://skidim.com/prodinfo.asp?number=R028023
    Heres some info as well as Chucks for you that might help , as these motors become more popular there will likely be more fore them looks like this guy may be cutting edge I'll find out more re OE type center rizers tommorow myself as I belive Indmar may selling some of these LS's for the roll bar crowd ? Tom
    Dec 2009
    Van Nuys, CA
    Wow those are cheap. Ive searched and searched, seen the raylar stuff and the cassell stuff....but those look like the best deal out there. Thanks!
    Dec 2009
    Van Nuys, CA
    Quote Originally Posted by Luckie Stiff View Post
    LSX-
    Sent you a PM
