C bowl to split bowl conversion
Results 1 to 14 of 19
    Senior Member lilrick's Avatar
    Lakewood
    Default C bowl to split bowl conversion
    anybody ever machined off the knuckle of a C bowl and convert to a Split bowl? I was gonna stick one in the mill and cut it the same width as a nozzle housing. I was wondering if the material in the bowl would be thick enough to drill and tap, or would you need to weld on a piece of material and go from there?
    Senior Member Rain Maker MN's Avatar
    Tommy at JBP does them....think there is a pic on his site if you want a closer look at the finished product.....
    Bakersfield
    Jack @ MPD does this also, it seems to be a viable option, especially if you've got the equipment at your disposal. Give it a go Rick! Take some pics.
    Lakewood
    guys, I know that there are paid people for this. I dont wanna pay! Lets do it ourselves!!!!
    Spiral out MikeF's Avatar
    Try it.
    Don't forget to post your findings as we all want to know your results!
    Quote Originally Posted by lilrick View Post
    You might want to at least check in with one of them for advice/tips. I would recommend the guy down the road from you in Costa Mesa.
    Back in the Hot Boat days, somebody took on this challenge and did what appeared to be a pretty good job. Don't recall ever hearing his performance results, though.
    California
    Yes, you need to weld a ring on for the flange
    Bakersfield
    Quote Originally Posted by MikeF View Post
    Try it.
    X2
    Santa Clarita
    the bowl itself does not have the material for it. you will have to weld a ring onto it.
    Lakewood
    i better go look for a hunk of material!!
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    What type of material is best suited for Welding ? lol -- is there a better steel to weld for this app .?
    What is Bowl materials metal composition ? Curious
    [/SIGPIC]
    Morgan Hill
    Quote Originally Posted by Lucky View Post
    A "C" bowl, among most others are made of cast aluminum, T-6 would be my choice...
    GT
    Senior Member sturat's Avatar
    Houston TX
    I do not know for sure but my guess would be 6061-T6
    Legalize the Constitution!
    most of the bowls are aluminum and a mixture of metals, i.e. cast aluminum, heat treated to a t-6 hardness for strength. you will need a tube or billet a little over 8in for the od and about 6in id and turn to final measurement. length to your choice, if you heat the bowl to 200-300 degrees and the extension it will tig easier. imo.
