455 Olds Pushrod failure?
Results 1 to 6 of 6
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Default 455 Olds Pushrod failure?
    What could cause pushrods to bend in such a way that I can't even get them pulled out after removing the rocker assembly. It happened on a stock 455. (a friends engine)
    The valves are not stuck - #8 cylinder - Intake and Exhaust.
    Any ideas?
    Morgan Hill
    Quote Originally Posted by Jet mad View Post
    Any ideas?
    Hydraulicing a cylinder can keep the valves from being opened, I would check for signs of inversion....
    #8 cylinder would be the closest cylinder to the water on a log deal...
    Could have tuliped a valve or two also...
    What type of guides were used in the valve job?
    GT
    I am not familiar with the guys engine or what has been done to it before.
    It happened at about 4500 RPM. No water in the oil either.
    Will probably have to do a complete strip down?
    Your theory on hydro lock is a definate possibality?
    Alot of steam came out the Exhaust at idle and it was about 40 degrees Celsuis today here (104 degrees F).
    bullhead city
    the valve can get hot enough to hang in the guide, done that before
    Shell Knob, MO
    If the guides are not clearanced for a jet boat application, they can seize and gaull when they get hot. Duane HTP
    X's 2 or really old "varnishy fuel" as well (seen this )
