Impellor or not!
Results 1 to 14 of 32
Impellor or not!
    Southwest corner AR
    Default Impellor or not!
    I got to test my new boat this weekend, YES! Boat ran good for stock 454 about 60 mph turning around 5800-5900 RPM! Well you know when I got back home out comes the stocker in goes the bigger motor! I know the increase in HP is going to probley need an impellor change I am running an A right now. The increase in HP will be around 660 double the 330 I pulled out! What would anyone suggest? I use the boat for fun not racing But, it will be tested!
    WT
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I've heard of people running the "A" impeller in their boats with 650 HP but not much over that. I just sent email to a buddy who builds Berk Jet pumps and asked him. I'll let you know for sure as soon as I hear back.
    Senior Member W.O.T's Avatar
    Campo Ca
    Congrats on the new boat. With 330 HP you probably dont have an A impeller spinning that many rpms. Your tach is off or you have a much smaller impeller or both.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by W.O.T View Post
    Congrats on the new boat. With 330 HP you dont probably dont have an A impeller spinning that many rpms. Your tach is off or you have a much smaller impeller or both.
    your dead on my friend,no way in hell will a stock style or even mild built motor turn a A impeller 5,800 plus,something is wrong my friend.
    you should be turning around 4,600-4,800 maybe with a stone stock mill on a full A cut impeller
    Glendale Arizona
    Agreed. Speed doesn't seem to match the rpm for an A. Also agree with the 4600-4800 rpm. Possibly even 4400 depending on whether it's a Berk or Aggressor impeller.
    Southwest corner AR
    Could be real loose LMAO! The tack reads correct at idle! I had an 79 SJ with a mild 460 and turned it 5800-6000 with an A impellor!
    When I had the pump apart it had A stamped on it and no bad sign of bad wear! I did test with the stock bowl on the trailer ran up to 5700 Rpm then. Changed the bowl to a JG split and the RPMs are still high! The impeller could have been resized I don't know but I will check sizes!
    Regardless it sounds like an impeller is in your future, unless your already running a stainless. I'll bet you end up with a "b" cut.
    Southwest corner AR
    Hotbo That is why I was looking for Scott S. I was going to get him to take a look at pump and placement or set! Shoe, ride plate,cav. ETC. Thanks WT
    Lexington, KY
    Go to this site it has a chart on it.
    http://www.arsmarine.com/Pump_Parts/impeller_chart.htm
    Southwest corner AR
    Sounds that way Im Thinking I got too much clearence will check that too! Thanks WT
    Senior Member Ken F's Avatar
    You might look at your impeller and compare the cut to this chart.
    Your impeller may have started out life as an A but could have been cut down to a B, C, or even D.
    Hope this helps,
    Ken
    MI
    What are the clearances on the wear ring?
    Santa Clarita
    A mild 460 wont turn an A to 5800-6000 rpm either. Something is off.
    lake Ouachita AR
    excellent idea my friend
