Removing the JE Berkley pump.
Results 1 to 10 of 10
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    Default Removing the JE Berkley pump.
    Anybody pulled a JE pump out without damaging the fiberglass? do you have to heat up the pump to make the sea poxy come out easier?
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Kingman/Golden Vly, Az
    just curious as to why u want to pull it out?
    FastRat
    FastRat
    x2, a rebuild should be done with it still attached to the hull
    Dec 2009
    Sac, Ca
    Have to get shaft out to get a new bearing on it
    Basically, it's easier to pull the engine than try to break loose the JE suction housing. Break loose is very discriptive- usually, you also take some of the glass with it, and then have to repair the hull.
    Dec 2009
    Sac, Ca
    I thought the shaft was pressed into the housing with the bearing? So If I remove the motor I can pull out the shaft from the front?
    Senior Member Cobra 02's Avatar
    Montclair
    Quote Originally Posted by nosfomoco View Post
    Yep pretty simple did mine last year, it was my first time.......
    Dec 2009
    Sac, Ca
    Dam. I must have had my head up my ***! I have rebuilt the JG style pumps a few times, I guess I was just used to getting it out! Well I almost messed it up. guess I gotta get the motor out!
    Charlotte, NC.
    hey man.. I got a Je and TONS of pics on how i rebuilt mine.. they are correct that you need to remove the motor and not the pump.. PM me and i can hook you up with any photos you need on how i did it..
    BTW.. one piece of advice.. remove the impeller nut and impeller before removing the engine.. It will help.
    X's 3 this jet was IMO not designed to be serviced out of the hull , once epoxied in place they are really "stuck" and would not remove it unless we needed to replace or repair the suction , Pure grunt and brute force are the basics if you were determined to pull it Not a fun job heres a pic of a Jacuzzi Golden Eagle (similar mount) Holy sh*t what a job !
