Place Diverter problems
Results 1 to 9 of 9
    Members only MAXIMUS's Avatar
    Close by
    Default Place Diverter problems
    Anybody experienced their hydraulic pump locking up when it bottoms out in one direction. I have to bleed off the psi from the lines to free it up again. One direction only???
    corona calif
    Default Place
    Alot of the time the sol seats are dirty or stuck, loosen the sols and make sure the smalls ss balls under the sol. are free. Also make sure you have a good ground right to the battery. If your 12 volt source is thru the key switch change it to a good 12 volt source. Greg
    Close by
    Thanks Greg.
    California
    x2, and when you screw them back in they should be barely finger tight (very light seat).
    Cas
    Cas is offline
    Angry American Cas's Avatar
    if they're still available, get yourself one of these, it cured mine from getting stuck and from slow operation.
    http://banderlog.com/products/powerR...owerRelay.html
    The Banderlog Diverter Power Relay
    • Feeds power to your trim pump directly from your battery.
    • Very simple plug-n'-play installation.
    • Does not need external diodes to work.
    • Works with any three way switch.
    • Built in fuse.
    • Complete kit includes wire, anchors and end connectors.
    Member ChickenCrew's Avatar
    San Antonio, Texas
    On my old pump, cleaning it didnt help. I called the manufacture and they said to trim down the small springs, but not too much. I trimmed about half a ring off the bottom and it worked good. Dont know how long it would have lasted, I replaced it before it went completely out.
    031 RIVER4FUN's Avatar
    Mine did that last summer. Took the hydraulic ram apart and cleaned it. It's worked fine since.
    San Antonio, Texas
    Do they have a seal kit for the ram?? Mine is leaking, but its not that bad though.
    Senior Member CP598's Avatar
    Sep 2008
    Quote Originally Posted by ChickenCrew View Post
    Does anyone know where to get a replacement ram other than Place?
