fuel line sizes
Results 1 to 8 of 8
fuel line sizes
    Las Vegas, Nv
    Default fuel line sizes
    I am in the process of putting together the fuel line system with stainless braided line and AN fittings. I need to know if there is a specific size line that should be use for the fuel lines ,especially from the tanks to the fuel filter, from the fuel filter to the fuel pump and from fuel pump to the carbs?
    The tanks had a 1/4 npt elbow with a push on hose barb with rubber fuel line to the "T". At the bottom of the "T" there is a -10 AN fitting withe -10 stainless line the rest of the way.
    The only fitting I could find for the tank with a 1/4 npt was with a -6 AN flare. The -6 line from the tanks just seem to be too small? ....Hal
    Kingman/Golden Vly, Az
    i personally run 5/8" USCG approved line from the bottom of my tanks to a T & 5/8" line from the T to the mech pump...3/8" ss braided line from mech pump to fuel log or y-block to carb/carbs...i also run a filter in each line comming from the tank to the T & another after the T to the pump...i have never had any fuel issues...just my .02 cents
    FastRat
    member
    Nov 2008
    Hal, give us some detail. What size and HP of engine? Electric or mechanical? One carb, Two or? Thanks Scott
    i'm back!! 1QuickCP's Avatar
    Montana
    1/2 pipe to #8 from each tank bottom rear to "y" into #12 to pump. never any issues.
    Salem,Or
    Im also doing the same thing with my boat and it seems Jegs has tons of diffrent fittings here is a chart i found a few days back
    http://www.performanceboats.com/html...fuel+line+size
    Las Vegas, Nv
    Quote Originally Posted by super junk View Post
    The pick up tube and bung on the tanks are 1/2" ID. engine hp is around 750,Pump is 140 gph mechanical, feeds two carbs. ...Hal
    Senior Member Futs's Avatar
    Orange CA, Big River
    I ran -8 from the tanks to the T. then -10to the fuel filter and then to the pump. -10 from the pump to the regulator and -6 to both bowls on both carbs.
    Redding, CA
    X2, on the Miller. (about 600 HP)
    10AN from single tank on the Hydro to filter > pump> reg. Then 6AN to all 4 bowl inlets. (Maybe 700+ HP?)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
