adjustable stops for hydraulic place diverter
Results 1 to 14 of 21
    okie, lake Texoma
    Default adjustable stops for hydraulic place diverter
    Lets see how you guys are doing it?
    I have seen a setup that actually clamped on to the side of the little hydraulic cylinder and had a short allthread with a hiem joint and a couple nuts on it but cant seem to find any pics or anyone interested in making one.
    Obviously this would be for a race boat application. Thanks , Hass
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    Nobody run one? Or is it some big secret?
    H8-2-W8
    here's a pic of one from that mach 1 tunnel
    #55
    one more
    #55
    okie, lake Texoma
    Thats the pic I was looking for Outlaw, thanks.
    H8-2-W8
    dats a nice setup! simple and functional, i'm diggin it
    i aint seen that mach 1 for a while, where did it end up ?
    it doesn't have to be that complicated. you can stack washers on the shaft of the hydraulic cylinder for an adjustable down-stop.
    the up stop can be as simple as some aluminum stock with a bolt and jamb nut that bolts to the side of the place diverter arm so that the bolt contacts the steering arm in the up position. I dont have pics of mine but I bought the up stop from MPD.
    Santa Clarita
    Here is my setup from MPD. It's just an upstop...Nice and simple. Sorry for the shitty cell phone pics.
    okie, lake Texoma
    What worries me about the solid stops pictured is that when it goes against the stop that little cylinder is damn stout and is trying to tear the small mount bolt, at top of the cylinder ,out of the aluminum and theres not much "meat" there. At least theres not on mine.
    Here's a pic of what I've been running. Seems the one on the Mach 1 would take the extreme pressure off of the top mount.
    H8-2-W8
    what was the point of this thread?
    you've already got an up/down stop that you feel is better than the others suggested.
    okie, lake Texoma
    No, I was thinking about changing it to be like the one on the Mach1 as I've always been a little worried bout it pulling that top bolt out of the aluminum.
    That little cylinder is pretty stout and seems like after couple hundred times of pulling up&down at full force it might become an issue. If you look close at my pic, that top bolt holding the cylinder doesnt have much meat above or below it.
    Was just wondering if anyone has had any issues there.
    H8-2-W8
    California
    I think its a trade off, with that style it's applying all that pressure to the base of that cylinder, it also looks like the pressure would put the cylinder in a bind.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Why did you cut your nozzel like that?
