Pit Pump
Results 1 to 10 of 10
Pit Pump
    Default Pit Pump
    Saw this very cool pit running set-up at San Diego last year Question is what type water pump is at the heart of it ? clearly it can withstand moderately warm h20 Any help is appreciated (nice boat too BTW) Tom
    Member JR131's Avatar
    we have the same setup on the alcohol dual jet
    it runs a standard bilge pump and yes it will stand up to the heat
    we have been running ours for about 10 years or so now
    jr
    Santa Clarita
    All the Jet racers run that type of deal....Just a bilge pump with alligator clips hooked to the battery and a 5 gallon bucket.
    we used a flo-jet brand pump that is used on the master craft ski boats and i suppose others for the wash down hose. same set up as shown just different pump.
    Thanks everyone , thinkin the temp my have been critical to the 'mix' Tom
    I use the same method to winterize the motor for winter lay up. It will empty a 5 gallon pail of anti freeze in under a minute.
    Salem,Or
    Ditto
    6TH STREET TERROR 4 HIRE -RUSSO-'s Avatar
    HESPERIA.
    Saw that boat at the drags.What is the plate/sheild bolted to the droop for??
    -FIX IT FASTER-
    -6TH STREET MAFIA -NOMAD-
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    Quote Originally Posted by -RUSSO- View Post
    Saw that boat at the drags.What is the plate/shield bolted to the droop for??
    that's Roger Sales boat "el bandito" the plate is because during launch the nozzle drags because of the droop and water gets splashed on his motor and he hates phoenix water and sandiego water getting on all the anodizing and coating on the boat you should see his tpr stealth you could eat of it
    Good call Chuck I just wanted to build a "fixture like this as a shop tool and was skeptical re the Bilge pump withstanding 180 or so temp , got the tunnel hull bruried in the back of the shop and cant get a hose to it !
    Quote Originally Posted by 78CoLeBBF View Post
    Jeremy, your right the water in SD is like battery acid
