Disconnecting the pump
Results 1 to 13 of 13
    Arcadia CA
    Default Disconnecting the pump
    I want to run my motor but Im too scared to run it with the hose. Can anyone tell me the best way to disconnect the pump? I have a hardin Marine Bellhousing on it.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Unbolt it...
    "Don't make me get my penguin"
    Arcadia CA
    Do I have to remove the bellhousing or is there an easier way?
    Kingman/Golden Vly, Az
    if u have the space...u can unbolt the drive shaft from the PTO/flywheel or take the u-joints apart...no need to remove the bellhousing ...just my .02 cents
    FastRat
    Cas
    Cas is offline
    Angry American Cas's Avatar
    if you have a 3 point mount and the drive line is covered, it's a real pain to disconnect. Does your bell housing have an inspection window in it? If so, it's possible to go through there to unbolt it but it's still real tough.
    How long are you wanting to run it?
    Arcadia CA
    It does have the three point mount and the inspection window....I cant imagine that window will be big enough to fit any kind of tools in there. I wanted to run it long enough to adjust my idle and make sure all my gauges are working properly.
    The Right Coast/SE-PA
    I have the SAME set up and it's virtually impossible to "un hook the driveline.
    With only .018 clearance between my imp and wearing I've been running my engine on the hose for years and years and years...NEVER any problems with doing so.
    Keep in mind, I don't let it run for a long time, just enough to fire it before I tow to the ramp or to set the timing.
    ALSO...I know my tail bearing is in good condition so...the impeller is not jumping all over the place or hitting the wear ring.
    I make sure, no water is going to my OT headers and water is exiting the block dumps as well as a healthy water flow to the impeller.
    If you're concerned about the shaft packing's, simply back off the tension, spray some WD40 at the shaft >don't forget to re-snug the bolts prior to hitting the water!
    Arcadia CA
    Bummer...guess Im going to have to rock the hose
    Cas
    Cas is offline
    If it's only going to be for about 30 seconds or so, you should be ok to fire it off. Just be sure to hose it out real well before you do and do not rev it up to 5000.
    These are pictures of the crap that came out of a freshly rebuilt pump with 0 run time on it after a 3 hour tow.
    Like Hammer, I fire mine off on the trailer to set timing, adjust idle and just before a trip to the lake without any issues.
    Charlotte, NC.
    I got the same three point set up. no way to pull it easily... It would be faster to pull the motor pull the drive line then reassemble with no drive line than try to pull the drive line with out removing the motor..
    So why not just take it to the ramp?
    If it's only going to be for about 30 seconds or so, you should be ok to fire it off. Just be sure to hose it out real well before you do and do not rev it up to 5000...
    Exactly Cas, don't fire it on the hose then go take a shit, shower and shave.
    And I'll only rev mine to 3500 just to make sure my timing is all in at 3000
    Cas
    Cas is offline
    actually, I don't even have to worry about running it on the trailer to set the timing anymore. Jim over at Performance Jet put my distributor on his machine so I now know it has 21º advance. I just set the static at 15º and know it'll be really close so I can wait till I'm on the lake.
    I just fire it off now to piss off the neighbors
    I hear you on pissing off the neighbors
    Since I finally went MSD-RTR I only set the timing when I pull the dizy to prim the engine after winterization >like I did two weeks ago
