Straight or Bent boots with Bassett twisties???
Results 1 to 7 of 7
    Arcadia CA
    Default Straight or Bent boots with Bassett twisties???
    Im about to order some new plug wires but I am also going to install my Bassett twisties. I have a 454 BBC and Im wondering if the I should get the straight boot or the 90 degree boot for these headers at the plugs. Any will be appreciated
    Senior Member 71kona's Avatar
    i run a straight boot 8mm wire with my twisties
    this boat will be the death of me
    prefer the 90's my self, but either one will work, depends on what wireloom you use and the length of the wire and the look you are after.
    Senior Member GRoper's Avatar
    i run 90's and run them down the back of the heads and up under the headers.
    Senior Member Dominator Scott's Avatar
    Feb 2010
    Lansing Michigan
    I run the 90 degree boots on my Sanger but the straight boots on my 32 Dominator. Either one will work fine.
    90 degree boots here too, down, then around the back of the heads.
    Arcadia CA
    Looks like I'll go with the 90s. Thanks fellas
