Wet Sand and Buff????
Results 1 to 12 of 12
    Arcadia CA
    Default Wet Sand and Buff????
    The Gel on the Carrera is getting nice and cloudy. I want to wetsand and buff it. Any recommendations? How much will I be spending for a 20 foot closed bow? Can I do it myself with no experience?
    Southwest corner AR
    It's a job and you can do it! I had a Howard flat that I did and it poped out when I sanded and buffed! The fade will come back in time! Take your time and it will shine! WT
    WT
    WFL Crew!!!
    Just give it a very thorough wash job with 1000 grit, rinse that off, do it again with 1500 grit, rinse that off, and once again with 2000 grit then you are ready to buff! I know its not the best out there, but I had really good luck buffing mine using the 3M Marine Wax & Polish! Wax it at least 3 times a year to keep moisture in the gel and the cloudiness should stay away! You'll be amazed at the difference.
    WFL Crew TINTDESIGNZ's Avatar
    East Texas
    Quote Originally Posted by towman3500hd View Post
    x2 ...except i'd skip the 1000 grit step and got straight to 1500.
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    Before putting sand paper to your boat, I would try a more conservative route.
    I had the same issue with my Hallett when I bought it. I went to West Marine and bought the Meguires 3 stage fiberglass restoration kit.
    It worked great for me, I was rather cautious about putting sand paper to my boat. It can't hurt to try this before putting sand paper to your rig IN MY OPINION.
    http://www.meguiarsdirect.com/detail/MEG+M4965
    Good luck! You will need at least a 12 pack for this job.
    Arcadia CA
    Quote Originally Posted by nick View Post
    That stuff is pricey
    East Texas
    everything to do with owning a boat is pricey!
    Quartz Hill/Havasu - Where Life Leads US
    The entire boats needs to be wet sanded? Usually only bad stuff where the glass is not smooth should be wet sanded, I just did a few areas of our boat this weekend that I had been neglecting for years. I color sanded with 1400 and then went to 2000. I mixed a little dish soap with the water. Once I was done sanding I used Maguires fine cut and glaze to buff the boat. It now looks like new. If its just cloudy you will be amazed what Maguires Professional products will do.
    Arcadia CA
    Ill give the Maguires a shot first
    just did my boat with this stuff it works really well
    classic hot boater Orange Peel's Avatar
    Mt. Island NC
    Default Wet Sand
    Check this out.. This was with 2000 grit and some real good 3M restore wax.
    Just one day at the house not really done in the pic.
    The boat was out side for 3 years??Cost maybe 100 bucks you do the work.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Arcadia CA
    nice
