Im about to buy a boat with a SCREW!!
Results 1 to 14 of 19
    Default Im about to buy a boat with a SCREW!!
    this winter i completly went through my boat rebuilt the old worn out berk with a aggressor bowl AT "A" impeller bronze shoulderd wear ring closed all the tolerences WAY up put headers lighweight flywheel, ballancer and a single plane intake on the engine cleaned checked rechecked and reinstalled everything and LOST mph last year with a .030 455, ported Ka heads, comp 280,ballanced,glenwood logs and a performer the boat ran a berk "A" to 4000 rpm and 67mph now with the setup i have i turn a fresh built pump AT "A" to 5100 rpm and 66mph! WTF did i do wrong? am i a complete idiot?
    Quote Originally Posted by glastornjet73 View Post
    you sure your tach is accurate? if you picked up 1100 rpm with a similar impeller cut you should be going significantly faster.
    thats exactly what i thought! idk if it is correct but it aught to be i JUST completly rewired the entire boat so i dont see why it wouldent be? could i hav e scred somthing up in the pump? the wear ring to impeller clearence is 0.025 and the clearence between the back of the impeller to the bowl is about the same 0.025-.030 so that seems good the engine seems to have a nice load on it and not be cavitating but my loader hasent came in yet so that might make a little diffrence
    just checked again 0.026 clearance the impeller has not slipped......it comes up to 66mph twice as fast as it did last year it just hits a brick wall do you think that is just all the faster this hull will go?
    Senior Member cruzer's Avatar
    Chandler, Az
    How fast is it at 4k rpm now?
    Cruzer
    21 Eliminator Daytona. Blown 540
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    Where did you get the impy? Are you CERTAIN it wasn't cut down or modified?
    Ray
    The Other White Meat! Pickle!!!
    bought it off ebay you could tell it had never had any machine work or never been installed and it sure lookes like an "A" usually u can tell by looking at the trailing edges of the blades
    Quote Originally Posted by cruzer View Post
    it is almost neerly dead on 1 mph per 100 rpm until WOT just that same as it was last year just no top speed mabye i should take out some wedge it diddent have much roost but i thought that was a good thing
    Chandler, Az
    No increase in speed from 4k to 5.1k? How are you measuring your speed? Gps or pitot speedometer mounted on the boat?
    Cruzer
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I'd measure the impeller and see if it's truly an A.
    no there is plenty of speed increase from 4xxx to 5100 just not what i was expecting it ran the same mph last year with a berk bowl and thorough transom exhaust
    mabye the boat wasent done picking up speed yet idk
    and it was a garmin nuvi stuck to the dash
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    What type of hull?
    "Don't make me get my penguin"
    AIR POWER TAPPED OUT's Avatar
    Las Vegas NV - Big River CA
    Lets see some pictures of this Beast!!
    Senior Member cave's Avatar
    Mesa, AZ
    Correct me if I'm wrong, But not all cuts are the same from different manufactures.
    A Berkeley A is different than a Legend and so forth. Could it be the Aggressor bowl with a AT imp. combo??
    When I rebuilt my Kachinas pump I didn't gain any speed. But I did get quicker. Tighter tolerances may have been the reasons.
    Takin it home
