455 carb
Results 1 to 14 of 20
455 carb
    Default 455 carb
    theres a holley carb for sale in the parts section said its an 800 is that to big for a mostly stock 455 with performer manifold
    use a BBC to pull a BBC devanwon's Avatar
    portland oregon
    its a bit fat but should work good. i had a 800 on my old boat with a mostly stock 455 and it ran perfect.
    Kingman/Golden Vly, Az
    Quote Originally Posted by devanwon View Post
    X2...IMO a 750 DP would work better! ...just sayin'
    FastRat
    what would the performance difference be between the two
    I had an 850DP on my alum.head 470 Olds that was too big for the engine at the altitude I run at @6000ft. I went to a 750 AFB.
    Hope that helps,
    Tim
    Monroe, WA
    I ran an 800 for a while, worked fine, but the plugs were black whenever I checked 'em.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    My friend Fred runs an 850 DP on his. Works great for him, but he stands on it all the time, so....
    what would be a good or best size then
    Quote Originally Posted by kona15 View Post
    a Holley 750 DP mech sec or a Edelbrock 750 AFB (1407)...just my .02 cents!
    FastRat
    its in a 21 foot kona day cruiser if that matters
    Senior Member Texgo's Avatar
    South east Texas
    I have a 800 cfm Q jet on mine. You said stock, right?
    Senior Member lowgear351's Avatar
    Jul 2009
    newcastle ca
    I have a mild 455 with a offenhauser tunnel ram with a single crab top I am running the summit 750 double pumper with mechanical secondaries it works great. it looks like a worked over holly 4150 .
    The price wasn't bad and it is polished so it looks nice .
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I also run a Holley 850 DP - only downside is fuel consumption.
    Bitch to sort out, but once sorted nice throttle response.
    JM
    seattle
    Default 800 dp
    i am running a holley 800 dp. i works great.
