Info on a boat
Results 1 to 6 of 6
Info on a boat
    Mar 2010
    Default Info on a boat
    Don't know much about this boat. But i'm looking at buying a 1982 Apache Jet boat. any info on these boats like the good and the bads.
ID:	71376   Click image for larger version.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by on 3 View Post
    Apache were good lake boats, pretty solid. If that's what you're looking for, a good lake boat that you can go out and have a good time, maybe 65 to 70 mph, it's a great boat.
    If you are going to have thoughts of going faster than that, the Panther pump will be your limitation. They can take up to about 500 hp but even with that, you're looking at low 70's as a limit. You're best bet would be to pass and find a boat with a Berk style pump if you have a bigger need for speed.
    If this is going to be your first jet boat, buy it, make it look really good and go out and have a good time. Panthers are a very good pump, lots of real good points but going real fast isn't one of them.
    simi valley
    Default boat
    boat looks clean 1 big problem is the nasty black thing sticking out of the back jk panther pumps r not very good though
    Always like these hulls , have worked on and modified a few This boat to my knowledge enjoyed a short run in Northern Cali in the late 70's early 80's Best of luck ! Tom
    heres a link for you to the Coast guard web site :
    Jason heres (below) a pic of one of our customers boats for you
    http://www.uscgboating.org/recalls/m...il.aspx?id=AHX
    Mar 2010
    Thanks for the heads up guys.
    I think in going to pass. and just keep looking.
    I like speed but its not a must, I live on the Tennesse River and our section is like a big lake. But i want the power and the big roster tail.
    Senior Member bigblock68's Avatar
    what part of tn you from
