Impeller question
Results 1 to 6 of 6
Impeller question
    Senior Member 79 Tahiti's Avatar
    Agawam, Mass
    Default Impeller question
    Pulled the pump off and took it apart there is a marking on the impeller with and H-A on it. I know it is an A cut impeller but what is the other marking for.
    Kingman/Golden Vly, Az
    Quote Originally Posted by 79 Tahiti View Post
    no clue!...get ahold of Tom at JBP or DuaneHTP...they can tell u & help u out with any ???...just sayin'
    FastRat
    "H" is a common stamping/casting prefix on Berk stuff, can't tell you what it actually means Is it a safe bet the Impeller is Green ? A picture might help Tom
    Cas
    Cas is offline
    Angry American Cas's Avatar
    it's possible it's an A cut Heritage impeller. Here's a picture of the one I'm running before it went in the pump-
    B1 Racing cs19's Avatar
    H=Heritage
    Cas
    Cas is offline
    Here's a couple of pictures showing the difference on the exit side of the Heritage
    and an AT, both are A/B cuts-
    anyone have any pics of a Berk and an Aggresser from about the same angle to compare the 4 together?
