no exhaust gaskets?
Results 1 to 14 of 17
no exhaust gaskets?
    Mar 2010
    Lancaster, CA
    Default no exhaust gaskets?
    newbie question. i took off my headers to make it easier to work around getting the motor in the boat and when i took them off i noticed there was no gaskets. are marine set ups different than cars? if they are supposed to have them could i just use some automotive gaskets or do i need marine? thanks.
    Senior Member bc18's Avatar
    Quote Originally Posted by vwracin2win View Post
    i use mr. gasket ones at autozone, work good for me
    Nov 2009
    Langley, B.C. Canada
    mined you i dont run headers but i use extream temp silicone. helps stop flange worpage on my aluminum flanges.
    Headers require gaskets on a boat motor. Measure to port size and shape and check your local parts store. If you can't find them. Post the engine type BBC or ford, port size and shape and somebody will give you a brand name and part number.
    Shell Knob, MO
    Some people confuse headers with log exhaust.
    If they are true headers, Wicked hit the nail on the head.
    If you are referring to logs or manifold exhaust, Left'y Pride hit the nail on the head.
    Different applications require different answers.
    Duane HTP
    Charlotte, NC.
    I find a good deal and usualy keep a set or two lying around. Every time i yank the headers off the gaskets are allways eaten up... Cheap enough to replace and Autozone has them locally. You can also shop online at like jegs or summit.
    I got tired of buying regular gaskets and replaced them with copper exhaust gaskets. I found a source for copper gaskets for Bassett Headers. Let me know if you want a set. Pat
    Mar 2010
    Lancaster, CA
    yea sorry i meant manifold/ log exhaust. yea sure if you have a good source let me know. thanks.
    Nov 2009
    log style DONT USE A GASKET. you will regret it not right away it will seal but after a season you will find that the flanges warped and now there off to the machine shop where they could not do the job with out taking the risers of where you will swear up and down taking them apart, then end up scratching them (more swearing) send them back and finally you think your done and a year later you start to see stress cracks around a couple of the flanges....... believe me i did it just go to the parts store and but copper seal silicone (extreme temp) get the glued on there and dont look back plus every time you take them off you dont need to run out and buy another gasket just glue more on. believe me my uncle did this to my boat before i got it, and i had to deal with the rest
    Have tried with and without...both regular and copper. What motor you running? If its a ford, the only logs n snails that will work correctly are the through bolt ones. I have em on my ford after constant attention to the flange type. Got my felpro gaskets at beans in elcajon...They never leak!
    Made In The Shade
    Custom Window Tinting
    anyone that has somthing that will work on a huge set of ported "Ka" olds heads with bassett headers i have used the stock manifold gaskets with prett good sucsess but replacing them every time i take the headers off sucks i bought a high dollar set of copper oned and there is a exhaust leak at EVERY port on the top
    Mar 2010
    Lancaster, CA
    i have a chevy 454.
    Alamogordo NM
    Dumb question previosly posted here.
    i have a chevy 454.
    Do your logs have the split/cut in between each exhaust port? I would run good a set of gaskets, but no need for copper.
    Made In The Shade
