how to put 4 point bbc motor mounts on rails
    Senior Member bigblock68's Avatar
    Default how to put 4 point bbc motor mounts on rails
    i have a set of glenwood motor mounts 4 point set up it where the feet the bolt to stingers would like to find a way to put them on a set of rails set my pump back and to run a pump brace from rails like to hear your ideas pics would be great
    simi valley
    Default pump
    so did u get the intake set yet?
    no i get it tomorrow they had trouble powder coating it but he said he have it in the morning so it will be wen. before i get to set it ill get ya some pics when i get it tomorrow
    I gotta a hunch to do this your probably going to turn the rails upside down at minimum as the amount you"ll have to trim/notch off the cast Glenwoods will leave little to nothing to attach the corner blocks. Might want to consider selling the G/W's and picking up some front and rear plates , just a thought !
