Question for the guys runnin a Ford....
Results 1 to 14 of 38
    Santa Clarita
    Default Question for the guys runnin a Ford....
    What Oil pan and Pump are you guys running and how much Cubic Inches / HP / RPM /Oil PSI is your engine making?
    Senior Member CP598's Avatar
    Sep 2008
    Canton pan, Melling HV, 600 inch, not sure about the HP, 6600-6800 rpm, 65 plus pressure.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Steffs, melling hi volume, Don't know the rest yet
    "Don't make me get my penguin"
    460 is offline
    ATTA BOY 460's Avatar
    466 cid
    m84bhvs pump
    85 cold idle, 40-50 hot wot, 25 idle hot
    spins 5k, 5600 on the bottle
    pan, dunno bought it off ebay when i first started the jet boat game. Holds 10 qts, i only run 9 in it
    Senior Member Hustler's Avatar
    Tujunga,ca
    You know what you need, pull that thing and get it done already. Memorial is just around the corner
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Williams 12 qt pan, custom rear sump pick up tube , Melling stage 1 prepped pump by www.highflowdynamics.com, 540 C.I. 931 hp, (not sure RPMS, have not tested yet, or oil PSI).
    What do you have up your sleeve Mike?
    Senior Member Green w Envy's Avatar
    Edmonds, Wa
    Quote Originally Posted by CP598 View Post
    Come on Vern..... isnt it about 1 hp per cube? bahahaha.....
    Darin
    Glendale Arizona
    Dooley 10 quart pan rear pickup (bolt on). Melling HV pump. Motor was 466 cu in and spinning 5300 N/A (500hp) and 5600 on the juice (650hp or so).
    Pressure was 50 psi unless you stay in it for a couple miles. When you hear the big whoosh.........get the hell off the pedal.
    Nov 2008
    Fuquay-Varina, NC
    Stock pan, stock cubes, bout 60psi
    '77 Caribbean
    lol, right..... Devilman's Avatar
    South Texas
    I've always heard that as long as you got 10 lbs. per hundred rpm, yer ok...
    That said: 460 cubes, parts store oil pump, factory car style front sump 5 qt pan, 300 HP (if I'm lucky lol), 4500 max rpm... Oil pressure 50 lbs cold idle, after warming up & running, maybe 30 lbs wot & dropping to around 18-20 at idle....
    Yeah, she needs a little attention, but been like that for 3 years & still gettin around... I ain't doin anything to it yet...
    Glendale Arizona
    Quote Originally Posted by Devilman View Post
    Ya know.......I was always worried about my seeminly low oil pressure (50 psi). Dan Nelson told me not to sweat it. The motor lasted 8 full seasons before it got rebuilt and I'm still using the same crank and rods. Pistons weren't all that bad either. Had just enough bore scratch to warrant going from .030 over to a .040 over. Guess he was right.
    On top of that I only changed my oil once per season and I run my boat alot. This was not Dan's idea though. Came up with that one myself. I think he'd have had me to change a little more often than that.
    So whatcha got going Pumper? New pan? It'd be cool if you could let the other true blue guys know.
    Senior Member zacho!'s Avatar
    tucson, Arizona
    dooley/melling as well, spins stainless A to 5200 all day and never drops below 70. Unfortunately I do not know many details on the motor other than bought from Louis Majors and it was built in PHX.
    Santa Clarita
    Quote Originally Posted by Hustler View Post
    Relax....been workin on it for the last couple hours. It will be out tonight.
    Not sure....trying to get some ideas. Cruising and idleing around, the pressure is ok in between 40-60 psi depending on how hot it is. After making a WOT pass it will drop to 0 if I stay in it long enough but will come right back within about 3 seconds of getting off the throttle. While making the pass you can just watch the pressure steadily drop. Everybody has a different opinion of what is causing it, crank airating the oil, oil getting stuck in the top end etc.... I'm currently running a 10QT Milodon and have tried all different levels of oil in it from 10 down to 7 quarts. Guys in the know have said they ran the same pan on a FORD and had the same problem and solved it just by switching to a better pan. Not sure but looks like that is where I will start before trying stuff like restricted pushrods and such.
    So.Cal
    Well...I hope you get that dialed in Mike. That sounds like a huge problem, dropping down 0-psi. If you decide on any manufacture pan, you obviously know my recommendation.
