Jacuzzi WJ Droop
Results 1 to 7 of 7
Jacuzzi WJ Droop
    Nov 2008
    Fuquay-Varina, NC
    Default Jacuzzi WJ Droop
    Anyone making one that bolts to the stock bowl? Or is an energizer kit the only way?
    '77 Caribbean
    Alamogordo NM
    As far as I know there is no droop currently for any stock jacuzzi jets, but i know tom at Jet Boat Performance makes an adapter ring that will let you bolt a droop for a berk style jet onto a wj. The only negitive is you will have to buy a new "nozzle" or diverter
    Nov 2008
    Fuquay-Varina, NC
    Talked to Tom through PMs and it sounds like I just need the adapter plate he sells and a droop, I guess the later Place Diverters will work...
    '77 Caribbean
    Denton, TX
    Quote Originally Posted by Storz View Post
    Really? I was under the impression that you had to get everything new from the bowl back.
    Nov 2008
    Fuquay-Varina, NC
    Quote Originally Posted by Btnhtillidie View Post
    That was my understanding, perhaps he'll chime in...
    '77 Caribbean
    The original Place diverters made for Jacuzzi WJ were indeed WJ "specific" where they attached directly to the Jacuzzi nozzle adaptor , in the early/mid 90's Place began to manufacture a new Nozzle housing (4 bolt bowl connection) and thus the same basic Diverter was used as the Berks etc . The late Place diverter will work with most late droops and nozzle adaptors (except a few Domy's) The very early WJ diverters will only work with the OEM Jacuzzi Tom
    Nov 2008
    Fuquay-Varina, NC
    You're a wealth of information!
    '77 Caribbean
