More or less?
Results 1 to 8 of 8
More or less?
    Senior Member GRoper's Avatar
    Default More or less?
    Anyone made noticeable power with less oil in the pan?
    Alamogordo NM
    Default ????????????????????????????????????
    Is a little more power worth possibly making your engine go BNAG?
    Nov 2009
    Langley, B.C. Canada
    only if its getting into the crank. thiner oil is going to get you more horse but same bang
    Senior Member W.O.T's Avatar
    Campo Ca
    what type of pan? i only run 8-9 qts in my 10qt pan. mostly due to oil psi issues and oil blowing out the breathers.
    San Diego, CA
    Quote Originally Posted by 74glencoe View Post
    quite the opposite. A little less oil in the pan will help keep oil pressure up and make more power. Too much oil is a bad thing and you will have oil pressure related problems such as windage and oil getting beat up and foaming from the crank.
    Boat 405.
    When you add tilt to the engine, such as in a boat, this changes the static oil level, often times submerging the rotating assembly. Keeping the oil out of the windage helps maintain cooler oil, and stable oil pressure
    Senior Member coonass's Avatar
    Canyon Lake, TX
    after add'n my 10qt B&B I put a full 10qts .......my oil pressure would fluctuate a bunch .........after lose'n about a qt it settle'd down real nice and turn'd another 100r's so yes there was a power gain
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    Quote Originally Posted by w.o.t View Post
    what type of pan? I only run 8-9 qts in my 10qt pan. Mostly due to oil psi issues and oil blowing out the breathers.
    x 2
