Jet boat BBC motor swap
Results 1 to 2 of 2
    Norco
    Default Jet boat BBC motor swap
    Helpin a friend. He has a mark IV block. He is thinking of putting in a Gen V motor. What needs to be changed besides mechanical fuel pump and oil pan? Will his intake and exht bolt up? It's a 3 point mount. Front cover ok?
    Senior Member Futs's Avatar
    Orange CA, Big River
    everything is interchangable that bolts to the block..IE..intake, exhaust. The timing chain cover and oil pans are the only difference. mark 4 heads wont fit right without a good gasket, but aftermarket heads work no problem. Thought we went over this at dinner........
