Transom header block off plates
Results 1 to 10 of 10
    Senior Member bc18's Avatar
    Default Transom header block off plates
    How Do u remove them? They are not fiberglassed seems like they are glued in or something but I've tried hammering them out and no budge
    Pie Wagon Newbomb Turk's Avatar
    Dec 2009
    Midwest
    Someone probably set them in 5200. Get a bigger hammer.
    "Does have a little wang in it...good though"
    Newbomb Turk...
    Kingman/Golden Vly, Az
    got any pics of the rear of the boat?...might help to see what ur problem is
    FastRat
    Charlotte, NC.
    To addrss the obvious. you did temove the backing plate on the inside of the transom that holds it in place right? If thats gone its most liley just silicone. I could not imagine needing "Glue" to hold them there.
    there is nothing holding them on the inside such ad a flat piece of aluminum they have to be glued in. im afraid if i hit it any harder im gonna crack the transom
    Charlotte, NC.
    Quote Originally Posted by bc18 View Post
    That suxs.. You got pictures?
    here are mine and what i would expect to find.
    Its a little hard to see the inside but you can see its two different peices bolted in the middle..
    Better shot.
    X2...except mine has a bar across the inside with a bolt & nut...without Pics, its kinda hard to see/tell whats the problem!!!!
    FastRat
    Senior Member CK7684's Avatar
    Minnesota
    When I went to remove my old exhaust tips, they were a real nightmare!! Make sure to try and cut around them with a razor to get through the silicone. Mine finally popped loose and I cant really say why...I just kept working at them without hammering away too hard. I was afraid of damaging my transom also...
    Arcadia CA
    I just took my tips off last week...it was a bitch. I cut around the silicone with a razor then put a long piece of 2x4 on there and whacked it out with a hammer. I knocked the shit out of it and didnt do any transom damage but maybe I just got lucky. I had to hit one side then the other because it was very snug.
    Good Luck
    ill try and cut with a razor blade and 2x4 but i will post pics for the hell of it
