not what i wanted to see
Results 1 to 12 of 12
    MPR FAB southwind011's Avatar
    riverside ca
    Default not what i wanted to see
    pulled the motor to fix a oil leak and install some new parts. found more then what i wanted to see.
ID:	71865   Click image for larger version.
ID:	71866   Click image for larger version.
ID:	71867   Click image for larger version.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Quik bearing set and crank polish
    "Don't make me get my penguin"
    riverside ca
    crank is already out being polished
    Member propless dancer's Avatar
    norco, CA
    dont fell bad. i took mine to elsinore last week, made one nice pass across the middle and it cost me a cracked cylinder wall and four pistons. I think the distributer vibrated loose and advanced it to comit suicide. at least we got a month till memorial day.
    B1 Racing cs19's Avatar
    Thats what Winter time is for, work on the boats so your dialed in for Spring and you just gotta make it to Labor Day then do it all over again .
    riverside ca
    i wanted to do this a long time ago but waited tell i moved in to my new house, im glad i found it before i wasted my block
    Senior Member TrollerDave's Avatar
    Chino,CA
    It's better to find it while the boat's in the garage. You could have been cruisin down river and found a lot more.
    When were those installed?
    Yucaipa, California
    Yeah, but what about Glamis?...never enough time!
    1992 Eliminator Daytona 21'
    riverside ca
    Quote Originally Posted by TrollerDave View Post
    dont know , bought the boat 4 years ago and this is the first time i have had the motor out. that was the only one that looked like that. looks like something went through the motor
    Jul 2009
    Quote Originally Posted by Tahiti Boss21 View Post
    Glamis, Thanksgiving week!!
    Canyon Country, CA
    Quote Originally Posted by propless dancer View Post
    If it came loose it would retard your timing. I don't know if it makes you feel any better. Sorry about your motor
    Quote Originally Posted by Robert Jonsson View Post
    Not necessarily. I had a jet boat with a mech tach. The dist was a little loose, and at 6,000rpms the loaded tach cable advanced the timing 100 degrees!! blew head gaskets between all cylinders!! I kept those gaskets for years to prove it could happen. I didn't think a motor could run with that much advance. But yes you're right, norminally it will retard.
