Still a GD oil leak...
Results 1 to 14 of 26
    Charlotte, NC.
    Angry Still a GD oil leak...
    Took the boat out after work. Its runnign great but i still have a GD oil leak..
    I know its coming from the valve cover gasket.. I have tried flimsy rubber ones hard rubber ones with metal inserts i have tried silicone..
    What is the BEST valve cover gasket for a SBC 350 and where can i buy it.. I dont care how much it costs.. Im just sick of a nasty bildge...
    Thanks!!
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Have you checked to make sure your valve cover isnt warped?
    "Don't make me get my penguin"
    Charlotte, NC.
    Quote Originally Posted by UNASHAMED View Post
    If you would care to share with me how that done i would be more than willing to check...
    MPR FAB southwind011's Avatar
    riverside ca
    take a straight edge and put it where the gasket sits and if you see any gaps. if there is any gaps that means they are warp and they wont seal where the high spots are. a ruler or a piece metal flat stock would work, just make sure it is straight
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Well if you have "stamped steel" then they are probly your problem. And use a good gasket with engine gasket sealer, prep the covers so that you have zero oil on the cover. Then apply the sealer to the cover and the gasket, let them get tacky, then set it in the cover. Repeat with the head! Get the parts clean first! Stay away from cork!
    Oh and get new valve covers too, If yours are old.
    Take them off and lay a strait edge along the bolt holes, look to see if you have gaps any were along the sealing edge.
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Nov 2009
    maybe you have a blow by problem thats why you keep having leaks or your not vented properly
    Dallas, TX
    Looks like he has a nice set of sheet aluminum covers.
    California
    I had a set of those for my SBF that leaked also, the internal tubes for the bolts to pass through weren't 100% welded to the flange, and that was the leak point. Mine were an ebay special , i ended up replaced them with a similar looking cover with an exposed flange.
    Lake Havasu az.
    Do the valve covers have a nice smooth shinny chrome surface for the gasket to TRY to seal to?
    Sheriff Joe Arpaio
    Glendale Arizona
    Quote Originally Posted by 2002CP19 View Post
    I always use cork. They work great for me.
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Those valve covers leaked on my old 468 as well. No matter how much silicone, & type of gasket I used, & tighten the piss out of the bolts, still leaked.
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    X2, Never a problem. But then, I don't run SBC's..........
    Ray
    The Other White Meat! Pickle!!!
    Senior Member lowgear351's Avatar
    Jul 2009
    newcastle ca
    I would check for crank case pressure. make shore your breathers are fully open. then maybe add a P.V.C. valve.
    Quote Originally Posted by So.Bay*310* View Post
    They suck apparently.
