carb mounting configuration
Results 1 to 7 of 7
    Feb 2010
    Default carb mounting configuration
    i have a set of holley 660 cent sqrt. going to mount them in line (bowl to bowl) i always se them mounted with the linkage on the left..can i mount them them 180 degrees so the linkage is on the right. it would simplify my cable mount.
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    Should be fine! Engine doesn't know front from back........
    Ray
    The Other White Meat! Pickle!!!
    Glendale Arizona
    Keep in mind, if they were push they'll now be pull (or vice versa) so you'll have to deal with your pedal/cable. Other than that you should be fine.
    Feb 2010
    that is why im asking because my cable comes around from the back and it pushes and that is what the carbs do
    Default 660s, a pair
    Quote Originally Posted by skippers WFOT View Post
    The 660s I have use a extended plate that comes down below to make it a "pusher" on the left side from the rear. There is a link to the other carb so they both pull together......JFYI
    LOUD BOATS SAVE LIVES
    Most carbs have the ability for the cable to mount to either the top or the bottom of the throttle plate, so push or pull shouldn't be an issue.
    Feb 2010
    these carbs dont have the lower holes for the cable mounts...id have to fabricat lower extensions
