Getting baffles out
Results 1 to 14 of 29
Getting baffles out
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default Getting baffles out
    so i have a set of bassett twisties and cant get the damn baffles out. Whats the trick guys?
  2. #2
    Done.... So.Bay*310*'s Avatar
    So.Cal
    Cut them off Adam. They look better shorter anyways...plus, when you remove them, you'll have holes in the tips. Just my thought.
  3. #3
    haha ya. is it a bust running without them though? the reason i want them out is because im gettin the jet coated.
  4. #4
    Kingman/Golden Vly, Az
    Quote Originally Posted by HBInHeat View Post
    ya, its a Bust in Calif lol ...but, as mentioned...they do look better!...also...u can then take the baffles out of the pieces u cut off, clean them up & re-install after u jet coat them! ...just my .02 cents
    FastRat
  5. #5
    Norco
    Get a penatrating fluid and soak em. Hang em from somthin with tips up. spray, spray and spray some more. Then try to get them to twist inside the header. That is what I did to get mine out.
  6. #6
    LF2
    LF2 is offline
    OC
    On mine I bent up around the bolt hole on the baffle with a screwdriver and stuck a piece of wire thru it then was able to pull on it. Not easy but eventually broke loose. You really need to remove them after every use if you dont want them in permanent or the will rust in. I didnt noticed any performance gain when I took them out so i just leave them in permanently now.
  7. #7
    ok so i have had them soaking and that hasnt worked so far so if it comes to cutting them shorter whats the best way to do it?
  8. #8
    a large tubeing cutter...any muffler shop or good machine shop should have one!
    FastRat
  9. #9
    LAID IN MEXICO
    santa paula, ca
    Default slide hammer
    slide hammer!
  10. #10
    Quote Originally Posted by nelson#109 View Post
    slide hammer!
    They make a slide hammer with visegrips. Soak them for a few days with wd40 and then get them hot. Now slide hammer them.
  11. #11
    i think im going to try a little bit of everones advice and see what happens. didint think this would be such an ordeal. do most of you guys run no baffles at the river? the only ca lake i go to is elsinor and thats just to test normally
  12. #12
    Senior Member 77charger's Avatar
    go to an auto parts store and get some pb blaster that stuff will loosen them up for sure way better than wd40 for this kinda stuff.
  13. #13
    slide hammer!
    X's 3
  14. #14
    Norco
    I soaked mine for 3 days. LOL.
