hyd. diverter lines?
Results 1 to 14 of 21
    Renegade jet tunneljet's Avatar
    Shorewood Il
    Default hyd. diverter lines?
    Anyone make there own stainless lines for the hyd. diverter? I don't feel like payin $240 for the line kit from Place. What size line, fittings did you use?
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by tunneljet View Post
    I used -4 line and fittings. works great.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    I can't post picts. from this computer. My picts are in the boat spam section, '74 Schiada...
    -4 SS female jic (an) on braided hose. got mine at a Parker distributorship here in NorCal.
    give up the lengths you need and I'll quote you.
    Mine are 27 and 29"s.
    Loose, the Dogs of War!
    Tom... I made my own too, Don't use cheap hose ends, when dealing with -4 fittings.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    I used 1/4" refrigeration lines with brass fittings, about $15.00. I wasn't about to pay that kind of money either. I changed the lines this winter just as a maintainance thing as they were still just fine. Not the prettiest around but very functional.
    Cas
    Cas is offline
    here's another angle
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    I made mine out of -4 line. I went with steel aeroquip fittings they are more durable, but after being lake water for a while they start to discolor and corode. But I had someone bump into a -4 aluminum fitting and brake it, they are pertty fragile.
ID:	72149   Click image for larger version.
    Shorewood Il
    Thanks for the replies guys. What about the size of the fittings that go into the pump and the solenoid?
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Just thought I would put it out there, I have a new set of lines and 90% fittings for a place diverter, these are the out board lines if you are interested I will let them go for $75.00 lines and fittings! let me know
    Tye ,,,,,, pm me for pics if you need them!
    Apr 2009
    se michigan
    If I can remember correctly I think they are 1/4 pipe. I know on the hyd cylinder they are 1/8 pipe.
    Bakersfield
    1/8" Pipe
    1/4 pipe on the pump.... 1/8 on the ram....
    Shorewood Il
    I took the old lines off and I forgot which line goes to which port on the diverter.
    Las Vegas, Nv
    Hey Cas how long are those lines and where do You get Yours? I can only find 5" long from Lowes and they seem way too long. I priced up makeing them from -4 ss braid line and xrp fittings and will cost a pretty penny....Hal
