is there a kit to drive the alt off the pump???
Results 1 to 14 of 18
    Default is there a kit to drive the alt off the pump???
    getting to the point on my mighty mouse project that i need to think of a alt set-up, kinda difficult on a ls motor so me and hass talked bout driving it off the pump instead. is there a kit you can buy or are they all custom built 1 off dealios??? i'm gonna have a 45-50amp draw when the motor is in full boost mode and the meth injection is on. wanted to go with jus 1 bigass battery, no alt but that's not gonna work
    Default Drive pulley
    Are you talking about a splined pulley that slides on the spline before the "H" bar? Can't say that I've seen one yet....I've seen all sorts of stuff ran off the back of a snout driven v drive, but there is no drive line back there to interfere. If you come up with a pulley arrangement, just remember an alternator is directional, I think.......I know a generator is......Thinking back, if you had a pulley welded on to the "yoke", it might work...But you'll probably have to mount the alternator to the stringer on a pivot to tension the belt.....It is amazing what you can do if some one tells you you can't!!! I doubt any of this would work with a "3" point mount set up.......Ray
    LOUD BOATS SAVE LIVES
    Senior Member slow67's Avatar
    DFW
    What about the BMR alternator bracket? Its designed for the LS1 style alternator on the LS block.
    Like this......
    yep, that's what i need don't want the alt on the driver's side, still need about 30lbs more on the pass side to balance out my wieght while in the boat
    Lake Havasu
    There were several pictures posted to a thread a month or two ago. Maybe someone can find it and post a link. I think they were all custom made though. Good luck on your search.....
    Last edited by Ahsumtoy; 04-14-2010 at 05:50 AM. Reason: I didn't mean to offend anyone...
    There were several pictures posted to a thread a month or two ago. Maybe someone can find it and post a link. Several looked pretty crude, but probably worked fine. I think they were all custom made though. Good luck on your search.....
    i may have to cut back the shaft alil and weld on a steel pulley, i had a feeling i'd be making it appreciate the pic though, gives me some ideas
    okie, lake Texoma
    An alternator can be run either direction as long as its new and hasnt been ran in the opposite direction. The brushes tend to wear. It will charge no matter which way you turn it.
    H8-2-W8
    [email protected] first pass
    Clovis, Cali
    This might be one of the crude ones mentioned earlier, but I was proud of it. It might help with the ideas.
    Steel pulley welded to the splined section of the drive line.
    Cheap Kragen chrome universal alt mounting bracket (on the rail).
    An extra turnbuckle as a tensioner.
    It worked good.
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    Default john mills
    Bubba made a nice set up. John Mills made this one for our boat..
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I have one made for a Lenco and the alt mounts to a pump brace.
    QE 439 Twin Turbo
    Lake Havasu
    Quote Originally Posted by propless View Post
    It worked good.
    That actually looks very clean. I'd be proud of it too! Definately not one of the crude ones.....
    Senior Member cripple midget racing's Avatar
    Menifee, Ca.
    Quote Originally Posted by RedPearl View Post
    Thanks Robert.
    I'm developing a new brkt. similar to what you have for my new hot rod.
    Yours is very clean.
    Menifee, Ca.
    Maybe you should go into production, sounds like there's a market for these things.... "Bubba Brackets"
    Yeah Right !!!
    Instead of having the name "Cripple Midget Racing", I'll change it to "Cripple Midget Machining" !!!
    It has a nice ring to it !!
    Menifee, Ca.
    Hey, I've got the CNC machines. Business opportunity
    I have my new brkt drawn up on a blueprint with all the dims.
    We'll talk
