Berkeley Pump ?'s
Results 1 to 14 of 14
Berkeley Pump ?'s
    Senior Member ironman's Avatar
    Clovis CA
    Default Berkeley Pump ?'s
    What is the purpose of the insulator that goes between the wear ring and the suction housing? I've been thinking about machining a bronze shouldered wear ring to match my impeller and just pressing it into the suction without the insulator. Has this been done before? Thanks for the help
    Ironman
    Norco
    I bet its to make the wear ring come out easy. It makes a tight fit when the wear ring is frozen. Ya melt the insulator to get it out if need be replaced.
    THis is just a guess.
    Thats a common fix for pump housings that have spun the wear rings prior, and would not stay put.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    it's to prevent the dissimilar metals from touching each other. If it didn't have the insulator, the aluminum and steel/SS would basically weld themselves together.
    Clovis CA
    what if it was pressed in with a thin coat of anti-seize and the wear ring would be out of bronze..
    Cas
    Cas is offline
    Quote Originally Posted by ironman View Post
    although I really don't know with bronze, I would think with the 2 different metals, corrosion between the 2 will still occur which can cause them to bond together. I don't know if you could put a thick enough coat of anti-seize to prevent that from happening without some slippage.
    Maybe the corrosion would put pressure on the intake housing and cause it to crack. Then the boat would sink!!! I would't want to think that even the possibility of that happening, could happen. Just machine it from plastic like an ultimate wear ring.
    as sleekcrafter said a good way to save the suction housing if the wear ring has spun in the hole. have done this several times through the years when a customer did not want to spring for a new housing. also i am sure one of the reasons the mfg's use the liner is that it take a pretty hefty piece of bronze to machine the pressed in ring. i purchase several of these blanks years ago from a fellow dealer and still have a dozen or so blanks left. also have seen some of his work that had been out there for years and no sign of corrision to the housing.
    be done with it and put in a ultimate wearring i hate, hateeeeee wearrings with insulators, i won't even touch em don't seal fo shit and they hurt impellors, no bueno
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    I know that on a Hamilton Jet unit there are an insulator behind the wear ring in the stator housing to prevent the brass impeller and SS wear ring from building up static electricity.
    Running without the insulator causes inteference with the electrical systems. I do not know if it is the same with the Berk,Dominator etc. I may be wrong.
    Running in salt water or water with a high salt content causes the sacrificail anadodes to corrode faster when running with out the insulators.
    JM
    Quote Originally Posted by johnray069 View Post
    One of my pumps has a pressed bronze ring, with no evidents of corrosion either, and is lipped like the current wear rings.
    Stainless wr on aluminum, and bronze impellers...
    Bronze wr on Stainless impellers.........as a general rule
    so ultimate wear rings are completly plastic? i was wondering because they are orenge! dam i wish i wouldent have let tom talk me out of one now....but how do they last compared to a ss shoulderd wear ring? i boat in a very dirty river!
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    The Ultimate Wear ring holds up great, I had my 21 Daytona with a blown 540 in the WI river 90% of the time I boated and it held up great!
    I checked it after a summer of fun and showed no signs of wear!
    Plus they are easy to install!
    Wonder why he talked you out of it??? Maybe wants you to bring back a pump soon for a rebuild??
    Senior Member lbhsbz's Avatar
    Long Beach
    Get an Ultimate wear ring....if for no other reason that it is softer than the impeller. Impeller's are more expensive than wear rings....so it's kinda dumb that wear rings are harder than aluminum impellers, or as hard as stainless impellers. Might as well call them wear impellers.
    I've got one and it works great if you set the clearances up like Duane tells you too...
