Another noob loader question??????
Results 1 to 5 of 5
    Member Bahnerman's Avatar
    Yuba city
    Default Another noob loader question??????
    I got a extreme loader....got it used with no instrctions....a weekend ago I bolted it in n ran it...and turn hard right when I let off the gas....my question is ???? Is how do cut it down???? Where do I cut???? What do I measure??? Btw it's a 83 bahner...530 dynoed hp...berk pump...with droop n pd...
    B.O.A.T - Beak Out Another Thousand
    Anything is for Sale for the Right Price !!!
    Is it hanging below keel. Mine needed to be cut back about a half of an inch.
    Senior Member Rain Maker MN's Avatar
    Get a straight edge under the boat and see how much is hanging down
    Southwest corner AR
    There are two ways to cut it down! Stright or angle since it is a v bottom and also check the welds where they are located when the excess is removed! Mine when cut down there was not much weld to hold the front of the ramp! Straight edge and a sharpie and see how much needs to be cut off even with the keel! WT
    Make sure that the loader is't bent or warped too!
    WT
    WFL Crew!!!
    Quote Originally Posted by Bahnerman View Post
    Critical to Know if that particular Bahner has a radius bottom or Delta bottom (quite possibly a Delta) when installing/trimming your loader if your not certain roll under the boat and click a pick to post up Tom
