76 Eliminator Re Build
Results 1 to 1 of 1
    76 Eliminator Semi V SC Johnny's Avatar
    Apr 2010
    Default 76 Eliminator Re Build
    Greetings all.
    I am a newbie to this forum looking for input.
    I have decided to re do this 76 Eliminator Semi V.
    I would appreciate any input on this hull design. I noticed a boat here called Propless that looks a lot like my hull. My boat has a ski pole on the front of the engine and a skeg mounted just forward of it. This baby has a shallow V and a ton of rocker. It also has fixed ride plates that were found in a very down or wet position. Engine was a low comp Ford 460 which was rusted shut and had water jackets full of sand. I only saved the block and crank shaft as both heads were cracked.
    Any info on this ride would be greatly appreciated.
    Loving old squirt boats,
    SC Johnny
ID:	72548   Click image for larger version.
ID:	72549   Click image for larger version.
ID:	72550   Click image for larger version.
Name:	Eliminator pre paint.jpg
