Drive lines
Results 1 to 14 of 26
Drive lines
    Senior Member Futs's Avatar
    Orange CA, Big River
    Default Drive lines
    What are the drive lines rated to? I have a 1310 i have been running with 800 hp and plan on hitting the silly spray and will put me over the 1000 hp level. Is this ok or should I upgrade to the 1350.
    If have this right, the 1310 is the smaller than the 1350?
    stop by OC drivelines (right next to sweet performance). those guys will take care of ya. I have them inspect mine before every season. Dont remember which one i have but they built several drivelines for me and are very good about checking them out.
    I know its good to go, but was looking for the rated HP levels. They have inspected mine in the past.Good guys. Have doing work with them for many years.
    Trick Flow 557 BLUE OVAL CP's Avatar
    Lomita, CA
    How are they on price compared to Rex or other marine shops? $300-$350 on those sites for the 1350..... I was thinking of upgrading from the 1310 to the 1350 due to the extra ponies this season. Think I should?
    Glendale Arizona
    This ad says 600+ hp for the 1350
    Glenwood Marine 1350 Driveline
    500-0845
    Category: Jet Drives & Accessories
    Brand Name: Glenwood Marine
    Jet H-Bar 1350 Driveline
    Heavy duty jet H-bar for 1-3/8" 10-spline jet pumps Uses 7/16"-20 bolts. For 600 horsepower and up.
    Quote Originally Posted by BLUE OVAL CP View Post
    If I'm not mistaken Sam, you'll have to move your motor forward an couple inches if you make the change. I believe the 1350 is longer. When putting my GW together I thought about using one. Decided not to because of the extra length.
    I'd already moved forward 7 1/4" for the jetaway and didn't want the motor in the back seat.
    Was also borderline on the HP rating thing with about 600-650 hp.
    Lomita, CA
    Yeah saw that this morning Dan. Might as well do it, why try to cheap out and save $$$ at this point right? What a joke.
    And I will measure what is in the boat now Dan. I have a little room to play with on the jetaway so hopefully it doesnt need to move, it is pretty far forward already.
    I just had a driveline/yoke change on my daughter's Crusader jet. The driveline shop here said it's not a 1310 or 1350. It's an industrial that's larger an stronger one. This one you can spot because it doesn't need a pto. It bolts directly to flywheel or flex plate. Shop says these are stronger. Just for info. Pat
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    Sounds like an industrial Rockwell drive-line to me. Obsolete item.
    031 RIVER4FUN's Avatar
    1350 is about 3/4" longer than the 1310
    MAMA TRIED BENSE's Avatar
    SOMEWHERE BETWEEN HEAVEN & HELL
    I upgraded mine from a 1310 to 1350 after some issues in my old boat.
    FILTHY FEW
    very good question, been wondering this myself.
    #55
    Glendale Arizona
    Quote Originally Posted by RIVER4FUN View Post
    Thanks for clearing that up. I knew it was longer, couldn't remember how much. All I remember thinking is..........if this motor goes any farther forward, I can use the valve cover for an arm rest.
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default shaft
    look up dennys driveshaft. Only way to go strongest one made. gonna do NJBA with the boat?
    Quote Originally Posted by ARS Marine View Post
    Find a used one, duh. They still make ujoints for them and probably always will. I think there's alot of them out there.
