new guy needs some help
Results 1 to 14 of 23
    Apr 2010
    Default new guy needs some help
    i just bought a 77 tri sonic tornado that has a 460 in it with a berkeley jet drive on it. the thing is i know almost everything about the motor but not on the jet drive. its been out of the water since 94. it has a new shaft in it but i just dont know if there is anything i need to make sure its lubed or what to do. thanks
    Senior Member Rain Maker MN's Avatar
    I would hit the bowl bearing with some new 90 weight oil, there are plugs on the bowl to change this.
    Then I would hit the shaft bearing with some grease, should have a zirc fitting to pump some in there
    I suppose the u-joints on the PTO could use some grease as well if it has been sitting
    Apr 2010
    ok i know your gonna say wtf but where and how do i do all that
    Should be two plugs on the bowl, small like 1/8 plugs.... take a wrench and remove them....pump the 90 weight gear oil through one of the holes until the oil pours out the other and the oil looks clean and new. if you don't know what the bowl is, well go to the berkeley website and look at a schematic of the pump
    The zirc fitting should be right on the front of the pump, near the bearing cap.....which is right where the PTO connects the pump and the motor together....
    If that doesn't make sense call someone like jet boat performance and they will walk you though it while you are on the phone.....
    Las Vegas, All Over..
    Berkeley jet has a manual on their website that tells you lots about the drives..thats a good place to check out too..
    Apr 2010
    ok so thats what those 2 black plugs are for lol and th only grease fitting i found lookc like a seal right behind the bellhousing it the bellhousing of the motor called the pto in the boating world??
    Quote Originally Posted by texan View Post
    if you have a pto...it will be connected to flywheel, then your ujoint, then pump. zerk will be right after on top near your pump id plate.
    Made In The Shade
    Custom Window Tinting
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    The PTO is the shaft with 2 universal joints connecting the crankshaft of the engine to the jet drive. Bolted to the crankshaft, and hooks to the jet drive on it's splined shaft.
    Sounds like you;re getting it!
    Ray
    The Other White Meat! Pickle!!!
    Apr 2010
    now i just have 1 more question. how can i tell what modle berk prop do i have how can i tell the difference??
    Nov 2009
    Langley, B.C. Canada
    well if it is stock to the jet on the model # on the id plate beside the grease Zerk they talked about you will find a model # mine is 12 jc a the A stands for the cut you can also find this on the bowl side of the "impeller" they dont have a prop but you can see that side at all until you disassemble the pump so you are going to need to believe they did not change it.
    Apr 2010
    all i know is it has tilt on it and the casting number on the bowl but what are the real difference in the jets
    Apr 2010
    ok its a 12jf-a what were these usually ran on
    Cas
    Cas is offline
    Angry American Cas's Avatar
    correct
    texan,
    Here's a picture from Rex Marines online catalog that shows what the PTO looks like along with the H bar drivelines-
    Apr 2010
    yeah mine has a bell housing and a solid shaft and thats about it
