spoon or race bubble
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 56
    Aug 2009
    Default spoon or race bubble
    how far forward of the intake should the spoon or bubble, whatever you wanna call it ,extend? myround keel intake sits below keel 1/4 so the body work to transition into it is about 18" from the front of the intaKE.if i put a 4' straight edge on itfrom the highest point(front .center of intake)theres a bit of a gap....should i make this spoon longer ?and take up this gap? again thanks in advance ....mikey
    Why does it sit below the keel? A spoon is not something to be done on the winger type hulls.
    Q.C./Big River
    Why not?
    Not that it don't work, it's the shut down and landing that suffers
    Aug 2009
    i reset the intake just as it was .it has the same amount of body filler as before the reset...ran great.i did have it hook after the engine shut down unexpactedly.but not too bad ,i thought it was do to more weight on the side it hooked to.ill get a ratchet someday.can anything be done besides using a ratchet or popoff to prevent or lesson the chance of a hook until i get a ratchet.......oh why not use a spoon on a gullwing?....thanks mikey
    Santa Clarita
    Where are you located?
    Aug 2009
    davenport iowa
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Drop keel on a V-bottom hull?
    Senior Member dragstr19's Avatar
    Chandler AZ
    Why not?
    X2=?
    Senior Member 787chuck's Avatar
    MorePark
    Quote Originally Posted by TRG View Post
    ya why not i did mine and with no shout down problems
    TRG
    TRG is offline
    I never said not to, my post was for clarification! hull type was never posted.
    MorePark
    sorry if i miss understood you it must be withdraws from not having the boat in the water
    TRG
    TRG is offline
    Quote Originally Posted by 787chuck View Post
    It happens!
    Arent the gullwing training wheels supposed to help on shut down (Sponsons)
