Gear oil for the berkley jet.
Results 1 to 6 of 6
    Member NeverLiftMotorsports's Avatar
    Mar 2010
    Pittsburg,Ca On the delta
    Default Gear oil for the berkley jet.
    Hey I have been reading about the 90 for the jet. Is there a brand that you perfer. I am thinking some redline its what we use in the racecar. Please let me know what you think.
    Senior Member IRRebel's Avatar
    Feb 2009
    Casa Grande Arizona
    Quote Originally Posted by NeverLiftMotorsports View Post
    I use Lucas, but I honestly beleive brand doesn't matter. Frequency does. Fill it till all the water and milky stuff is out and often, you'll be just fine no matter what you use. Just my .02
    Ray
    The Other White Meat! Pickle!!!
    Mar 2010
    Thanks Ray! Ill change it in the am.
    The Right Coast/SE-PA
    Burning money putting high dollar gear oil in the bowl >no gears, just a shaft and two bushings. Heck, I'll use the cheapest gear oil I can find and/or just use some straight wt motor oil.
    Senior Member bc18's Avatar
    Default Gear oil
    What weight do you guys use? 90 you say?
    i refilled mine every time i took the boat out last year! no wear on the pump when i took it apart but i am greese lubed now!
